Seat Bolt
pubrunner
I need a seat bolt for my 753 frame;
attachment.php
size M6 X 26 allen bolt.
Can anyone tell me where I might acquire such a bolt ?
Out of interest; IF I happened to be offered a bolt in a choice of materials such as Steel, stainless steel, titanium etc., etc.,
are there any materials that perform the task better than others ? Are there any materials (for such a purpose) to avoid ?
Ta for any info.
Regards
Andy
youngoldbloke
Is this the sort of thing you are after - from PBK, £1.75. Not sure of the size, but standard Campag style replacement.
tyred
Ireland
I would go for stainless steel if I had a choice of materials. You won't find the threads have rusted a few years down the line when you decide to remove the seat pin to grease it as part of a thorough service:biggrin:
gbb
Peterborough
Absolutely sure its 26mm long and not 25 ?
Standard bolts will come in 25....26mm would be a special and i think you'd struggle to find one anywhere other than a bike shop.
(I'm assuming you mean a standard bolt, hex or allen head...not one that youngoldbloke has highlighted)
In the photo, is the boss threaded 6mm on one side ?..ie you dont need a nut.
02GF74
^^^ we need to see the other side to tell whether it is just an allen head bolt or the special clamp bolt (more likley on a steel frame) as above.
stainless is not really ideal for highly stressed areas.
you can always try a stainless bolt and if you have snapped it because the seat post keeps slipping, you know you need a high tensile steel bolt. bit of coppa slip should prevent it from seizing.
