Seatstay rear lights?
tyred
Ireland
Get a small P-clip in whatever diameter your seatstay is and use it in place of the part of the bracket which fits around the seatpost.
+1 for a rack mounted light, much prefered and puts it right where it cannot be obscured by stuff on the racks, long coats etc. My topeak wedge has a loop for clip on lights, if your saddle bag doesn't have one, you could likely sew a simple loop on there.
mjr
Great image, showing that the light on a saddle wedge points at the ground far too much.
Also, technically, does it count as a legal light if it's fixed to a bag not the bike? Ones on the rider don't.
mangid
Cambridge
I carry a flare as a get out of jail backup (used it once in 6 years I think). Put some grease/vasoline in around the silicone battery cover if you do get one as it's not that watertight.
Sixmile
N Ireland
Another vote for the fibre flare. I use one during the winter months as a second light on my right seatstay. I've been through 2 winters with it so far without issue. I'll get maybe 3 return commutes before I'll top up the charge again.
ianrauk
Tattooed Beat Messiah
Rides Ti2
I found this out when I first bought them a few years back. Only a couple of rides in and water ingress killed one of them.
Glasgow
Same here, I did buy one some years ago after reading about them on the bargain thread, the light was dead after the first downpour :cursing:
Ming the Merciless
There is no mercy
Inside my skull
Yep put one one on each seatstay. Nice diffused light that does not blind a following cyclist like many direct lights do. Get the AAA version and it will last winter of commutes before batteries need charging or replacing.
alecstilleyedye
nothing in moderation
Great light until it gets old, then it can't hold a charge. I replaced mine after the 2nd winter of regular use when if you forgot to charge it immediately pre ride (not the day before) it'd power off without warning and given its a rear light its hard to notice that :wacko:
mine gets a daily charge at work, it doesn't last as long as its older lezyne micro sibling…
Mr. Cow
Manchester
It seems fibre flare light are no longer available - it looks as though the company may no longer be trading (although I could be wrong). Could do with a new one as I have to keep removing corrosion from the contacts, hopefully will last a bit longer now I've waterproof/greased the lower rubber cap. Anyone know of a similar thing to a fibre flare... which isn't a fibre flare? :smile:
