shifters
RecordAceFromNew
Swinging Member
West London
They will work with cable operated "mtb" disc brakes. In case you are unaware not all disc brakes are cable operated, and cable operated ones come in either mtb or road versions.
You can get them cheaper here.
On the other hand if you want ones that work with any cable operated disc brakes you can get these - they have a little lever inside that allows you to use either mtb or road specific brakes.
In case you are unaware they will only go on to flat bars. Drop bars usually have larger diameter.
