Probably not, but you will then know which it is from the appearance of itI can't really afford to get someone else to do the wrenching, if I take it off will there be a part number?
The one I linked to in my previous post was the correct model.I can't really afford to get someone else to do the wrenching, if I take it off will there be a part number?
Yebbut that's irrelevant.I recently stripped the Shimano compatible one on my Mavic wheels and it was the same as I linked to above.
"Shimano compatible" just means the spline pattern and that you can use Shimano cassettes on it.
