Jonathan M
- Merseyside
My MTB has recently come out of retirement and is seeing some good use again. The components in question are Shimano LX pods, which date from around 2004. It is the rear shifter that seems to be problematic, and it is running with an XT rear mech of a similar age. The mech is a standard pull one, not one of the reverse pull versions, and I'm running with goretex cables, there does not seem to be any gear cable stiction as when it does shift it shifts well. The bike has been pretty much unused since about late 2005, and when I did stop using it regularly I can't recall a shifting problem.
The symptom is this: When on the larger cogs of the casette the thumb lever (to shift from small to big cogs) can take up to three sweeps before I get one gear shift.
On the smaller cogs shifting is fine, the usual of one thumb sweep giving up to 3 cogs on the back.
It means it is sometimes easier to make a chainring change rather than try and shift on the rear, meaning at times it is like riding a 3 speed bike.
My riding mate thought it was a slack gear cable, but this isn't the case - besides, if a gear cable is slack then you have to take up the slack before the mech shifts on the smaller cogs, and the larger cog shifting is usually fine. I've got to admit that it almost does seem like a cable tension problem, but it just happens at the wrong end of the cassette for it to be a cable tension problem.
My thought is something internal, so I've generously sprayed some GT85 through the shifter cable port, got some dirt out in this manner and on the driveway it seemed to be slightly better.
I'm assuming that this means a new shifter pod if a more thorough strip of gear cable & flush with GT85 & lube doesn't solve the problem, but has anyone else out there got any suggestions?
