Shimano R500 30mm, cheapest?
Can get the 501 for £70, not sure what the difference is, upgraded hub according to professor google
Quidco from merlin too
http://www.merlincycles.com/shimano-r501-wheels-49086.html
Are you sure these are really an upgrade, are the current wheels worn out?
P
PLuKE
Suffolk, Ipswich
Thanks, but looking at the 30mm rim depth.
The current wheels having worn out no, around 350-370miles on then at present. I wanted something lighter and look good to with the 30mm depth.
Luke
They're just stock rims generally found on specialized bikes
Not sure there'll be a great benefit with entry level Shimanos unless you like the deeper rim specifically. Get decent tyres too
Cyclist33
Warrington
I forgot to add the link! In my defence I did said Ribble Cycles.
There is no real info on the Alexrims.
Luke
The Alex website has (some) wheelset specs...
Cyclist33
Warrington
But I don't know if R501s are a big upgrade and I'd be genuinely surprised if the Alex ones have genuinely worn out already.
Vision Team 30s can be had for around £200, 30mm rim depth and bloody quick wheels - mine weigh 1770g (1010 rear, 760 front).
Mind you there are always deals to be had with wheels... I got some Shimano RS30s a couple of years ago which while not exactly light (about 2k the pair), looked truly great and rode stiff and quick especially on flats and downhill. RS31s are 100g lighter.
