I like Skol
A Minging Manc...
- Sunny Ashton-under-Lyne
I need a new bottom bracket for my road bike. After only 1.5k miles the factory fitted item has developed rough bearings that can be felt when turning the axle with the cranks on or off and is clicking when pedalling.
The OEM unit is THIS RPM item and while I could possibly find a way just to replace the actual bearings (it is a simple design that appears to use off the shelf bearings) what I actually want is to fit a Shimano UN55.
The problem is that the size is unavailable. From what I have seen, 68x103 has been available in the past but not anymore.
Does anyone know of a supplier that can get a UN55 in the 68x103 size or, alternatively, what other bottom brackets are available at a comparable price and quality to the shimano (i.e, costs £20ish and lasts forever
Before anyone says it, I know the 107mm version will only move the chainline by 2mm but I want 103. The transmission runs perfectly as it is and I don't want to alter that.
