Shoes Pin's and Needles
segovia
Member
Hi
I just bought some new shoes that were fitted in the shop that I bought them from.
The cleats need adjusting as I have pins n needles in my right foot toes, does the cleat need to go forward or backward ?
Hi
See here https://www.cyclechat.net/threads/help-a-novice-day.181921/#post-3749062
Cleat should be over pedal axle. Youll probably need to experiment, presume you have compared to the cleat position of your old shoes?
zacklaws
Beverley
I don't think you will find it a being a cleat problem. Its more to do with your blood circulation and probably caused by the shoe being too tight, the insole or your foot swelling slightly when it gets warm. Try loosing the straps for a starter. To prevent myself over tightening my shoes, I always unfasten all straps before putting my foot in the shoe just in case my foot is more swollen than the last time I wore them and also pull my toes back which causes your foot to arch slightly and then tighten the straps which allows just a bit of space to allow for your foot swelling and also a bit of room to wiggle your toes. Another thing to try is wiggle your foot and toes about every now and then, Also a different type of sock with more padding on the sole may help, or you may have to try a different insole. Providing your shoes are the correct size, the pins and needles will go away eventually as your feet get used to the shoes.
buggi
Bird Saviour
Solihull
What he said. If you have more than one strap, it's usually the middle one across the arch that I find is causing the problem.
ozzimogg
Hi
I had pins and needles as well at first, I purchased a cheapish pair to see if I like them, they are fine now though, When I first had them I thought they were a bit stiff and tight, I then realised I had left the cardboard linings in for about 4 rides,LOL
blackgoff
Hi
I'd try and return them and get a pair that fit - comfortable / close (fitting): NOT the other way round...
Or get a pair of Bonts...
