ChrisEyles
- Devon
I've been thinking about trying out a short stem/wide bar combo on my old-school FS Marin. It's currently got 600mm bars (with a little rise and a tiny bit of back sweep) and a whooping great 120mm stem.
First off, whatever else, that stem is just too long. I've got some bar ends on, and if I try to use them on a steep climb I invariably lose all traction on the rear wheel. So one option is to keep the narrow bars and get a 100mm-ish stem - this would make the reach, stem length, and bar width very similar to my similar vintage rigid bike, so I guess it should work fine.
However, while I do get on well with the long stem / narrow bar combo and enjoy the way the bike handles on smooth-ish tracks, I've been finding that with the FS, which enables and encourages you to go much faster on rough stuff than you can on a rigid, I've had a few hairy moments trying to hold the line I want to through rocks and ruts. I guess this is partly because the narrow-ish bars give a bit less leverage, but also because the long stem means the left and right hands don't really oppose one another much when the wheel turns (i.e. it's not an ergonomically strong position to resist the wheel being turned). So I've been thinking of getting a cheap 60-90mm stem and 680-720mm riser bars and seeing how I get on with them.
I've ridden a 90mm stem with a 700mm bar on a modern hardtail quite a bit, and while it felt horrible at first, I've now got used to it and actually quite like it. However I've no idea if the head angle is slacker, or the top tube of the bike longer than on my late nineties MTBs.
T'interwebs is full of armchair theorists on the subject, but I haven't been able to find accounts of many people who've tried the switch on a retro MTB (with associated steep HA and shorter top tube). Anyone on here taken the plunge, and if so did it work, or is this set-up not really compatible with older bikes?
