slight buckle
nickp
I have noticed that my rear wheel is very slightly buckled and is rubbing on my brake pad.
Is it easy to get fixed or will i need a new wheel?
TIA
ianrauk
Tattooed Beat Messiah
Rides Ti2
yes easy to do, however if you are not that confident, off to the LBS with you.
Here's a vid showing how
Trumpettom001
It can be fixed -by altering the tension on the various sides of the wheel.... which then pulls the rim back into alaignment. The spokes have a thread which fixes into the "bolt" or the bit next to the rim of the wheel, and by twisting these little silver things, it pulls the rim into shape.
I've managed to fix a wheel that had about 2cms buckle in either direction - although I would'nt reccommend doing so if the buckle is that bad.... anything up to about 7.5mm should be O.K.
google "trueing a wheel" or youtube or whatever - it's somthing you get a bit of a knack for.... but I warn you now, you do need to definatley be comfortable with which way is tighter and looser, and then reverse it depending on which way you're looking at the wheel. also, if you're going to be doing it again and again (like me and my stupid alex ASD-1 rims) - get a semi-decent spoke key.. makes life sooo much easier than using an ajustable spanner and basically stripping the bolt of the spoke..
02GF74
what do you mean by buckle?
worst case the rimn it self is damaged - this can to some extend be bent back and a major prang would cuase that in the first place.
more likley your wheel is out of true - see wot they say about adjusting spokes.
N
nickp
Thanks guys.
I don't think i'll try doing it myself as i'd probally just make it worse, off to the LBS tommorow.
Andy in Sig
Vice President in Exile
Getting a small buckle (or even a big one) out of a wheel is surprisingly easy. All you need is a spoke key, which costs just a few pence, and maybe a bit of chalk to mark where the centre of the buckle is. A good idea is to get a good general book on bike maintenance which explains it all in straightforward terms. I use Bicycle Technology by Rob van den Plas.
swee'pea99
It's really easy, takes 10 mins.
Think of spokes as long thin bolts. Each one has a 'head' at the hub and a 'nut' (aka 'nipple') at the rim. And each attaches to the hub on one side or the other.
To move the rim at a given point to, say, the r/h side, just follow a spoke at that point on the rim down to where it joins the hub. If it joins it on the r/h side, tighten its nipple and loosen its neighbours - about 180 degrees turn at a time. Repeat as necessary.
A tip: if you get confused about which way is tightening, and which loosening, imagine that instead of using your spoke tool you were using a screwdriver on the top of the 'bolt'/spoke.
swee'pea99
Nope. Turn your bike upside down and as you revolve the wheel, look at the rim by the brake blocks - this will tell you where exactly the rim is too far to the right/left.
simon_brooke
Auchencairn
nickp said:
First question, i don't have a truing stand, is this going to be a problem?
A truing stand is nice to have but not necessary. I didn't have one for the first pair of wheels I built. Just turn the bike upside down, and use it.
Use a rubber band or some tape to fix a pencil to the forks (if front wheel) or seat stays (if back wheel) to give you a position reference to work to - you can use the brake but I find it easier to remove the brake and use a pencil.
Generally, tighten/loosen the spokes at the centre of the wobble most, the ones one away by half as much (so half a turn for each full turn on the worst one), and the ones two away by quarter as much.
For conventionally built wheels (28, 32 or 36 spoke, radial, one, two or three cross) this is really easy. For some of the fancy spoking patterns used on some modern factory built wheels it's less easy but by no means impossible.
N
nickp
And so the problems start:sad:
Just got back from halfords only to find the spoke key i have dosen't fit, it has 3 sizes which are 14g, 14g asia and 15g.
I have had a look for larger sizes but can't find any, does anyone know where i can get one?
Cheers
