Hi CC crew,
my ye olde turbo trainer bike, just at the weekend under reasonably high power (for me) slipped 2 or 3 times, it felt like a very minimal slip, but a slip all the same.
It's running 105 5700 10spd, but is using a zwift cog at the rear, all be it for Rouvy and TrainerRoad.
In all likelihood, the chain has probably been in use for a lot of hours.
This turbo, cog and chain have been running together with no issues for just over a year.
The chain is however quite a bit older, though I forget how old exactly - I do recall refreshing the chain and cassette a while back, but it might be as much as 3-4 years potentially.
Slightly annoyingly took my last new 10spd chain to Spain for my daughters bike earlier this year, but am pretty sure I have a few 11spd options knocking about.
Would I be safe to use an 11 spd chain, and or is that the most likely culprit?
I think I have one of those chain wear gauges somewhere, so if I can lay my hands on that, I suppose I should use that in the first instance.
I've no idea if the zwift cogs have reliability issues, or of course I suppose it would be the inner cog on my chainset - presumably just changing the chain is the obvious first step, but I was just unsure as to whether the 11spd chain would happily co-habit with the 5700 chainset.
I'm assuming the rear cog will be fine, as I think it is sold as accommodating a massive range of bikes on it.
