Thanks for the advice.. I was thinking of better tyres, the Schwalbe Smart Sam that came new with the bike are OEM versions so not as good as retail versions as confirmed by Schwalbe...
They recommended the Schwalbe G-One All Round as a good tyre and the "micro skin" version seems a good tyre, I think it is 127TPI rather than 50TPI I have... although the retail version is 67TPI
THis was there replies....
Hi Stuart,
Thanks for taking the time to get in touch with us, your question is a good one!
You are correct; the version you have on your bike is an OEM tyre that is slightly lower performance than what you find in an aftermarket tyre. The tyre you currently have will be slightly slower rolling, less protected and will probably wear out quicker than the aftermarket verion. But they are produced to help cycle manufacturers reach thier chosen price points.
We do a full aftermarket version of your tyre in both wired and folding beads. Both of these feature the higher tpi carcass and more substantial puncture protection. In addition to this the compound of the tyre is much better too. It just depends how much you want to spend really. The wired version is heavier, but also cheaper than the folding version.
Width is also up for discussion as we don't do a direct 42mm counterpart, but we do a 40 or 45. If you can fit it in the bike I'd always recommend a wider tyre as they roll quicker and are more stable and comfortable.
I hope this information helps, but if you have any more questions, then please don't hesitate to contact me.
Kind regards
Ben Tomkinson
Schwalbe UK
Hi Stuart
No problem, we all ride bikes so talking/emailing about them is always good!
Personally I'd say the G-One All Round....my personal favorite, and despite the fact that I'm lucky enough to get free tyres and I can try anything, I've had 6 sets on the bounce. Very tough, very fast and extremely grippy! The 700x38mm is quite high volume and very comfortable.
We do a cheaper performance version, and a higher end micro skin version that's tubeless, and I'd recommend that, as it's even quicker and tougher. Well worth a look.
Hope this helps!
Regards
Ben
