ClichéGuevara
I'm in the throws of tweaking an old mountain bike for commuter/camping use. (Raleigh Glide) It had twist grip shifters, which had lost the ability to index, so as I was replacing them, I thought I'd improve the gear range, so changed the freewheel from 14-28 to 13 - 32 with Acera shifters and a HG 40 chain. I checked and oiled, but didn't replace the outer cables.
Because of the order they came in, the shifters went on first, but I only set the gears roughly as I thought they'd only need resetting later.
Next on was the freehub, with the old chain. This seemed to work well, indexed across the range, but if I pedal backwards, the chain dropped from the large rear cog towards the middle gears and jammed (not toward the wheel). It was fine going forwards and freewheeling. I assumed this was the chain.
It didn't make sense, but the machinehead chain length calculator, gave the same length for the new as the existing chain, but as it worked, that's what I did. It has the same issue when back pedaling. (from memory, 42.5 hub to hub centres, 42t - 32t, but don't quote me)
I run out of time to look too long, but thinking about it, could it be the jockey wheels? They seemed free enough, but that's only from threading the chain on, I've not specifically checked them.
Any suggestions?
Any suggestions?
