02GF74 said:
I find it very hard to believe that any human can break a chain using regular gears.
Surely the strongest guys - TDF riders - would be snapping them all the time?
Or do they have super string chsains made for them?
I can only presume the chain was faulty or more likely the fitting of the last linkg was not prefect.
Did you examine the chain to find where and how it failed?
Have you never had a chain break?
I've broken a chain 4 or 5 times in 15 years of cycling, and others on here will have broken more. Two of those were on Shimano chains, so I'd ask the OP if he knows what make of chain he broke?? I'd always prefer to use something other than Shimano when possible, and whenever a Shimano chain has broken I've always replaced it ASAP.
One other break occured on a Sachs/Sedis chain, but the weak point was one of the chain joining devices, that had been through about 3 previous chains, so simply the side plate wore out.
But the chain joining links can be handy to carry for a repair, although a chain tool might still be needed to remove any damaged links that have occured.
