Hello,
So I have just bought this bike. But unfortunately I have had an on-going issue for quite some time with carpel tunnel syndrome, and now it has gotten to be bad enough that I am not even going to be able to use this bike, sadly. So it is brand new. I have every part receipt, which can be given to the new owner.
Everything is perfect on it. It's been expertly and meticulously built. I have built many bikes over the years, and at one point for quite a while was employed in this role. Every single bolt is torqued, anti seize paste applied, chain length is perfect, clear protective tape on all cable rub sites and chianstay etc. The shifting action is flawless and instant. And the brakes are perfectly set up. It's very light, around 9kg even with the accessories on.
I spent lot of time choosing components for it. Every part choice is quality, performance and value orientated. And I think I came up with something quite special.
The itemised build listis as follows:
Kinesis black T2 frame, £184.99.
Deda Black Rain forks, £87.99.
FSA Orbit headset, £27.49.
Shimano 5800 11 Speed 50/34 11-28 Groupset, £300.
Campagnolo Zonda 2014 Wheelset, £250.
Continental GP4000s 25mm tyres, £55.
Contiinental Race inner tubes, £8.
SKS Chromoplastic narrow guards, £28.
Selle Itallia XO Special Edition Saddle and seat post, £34.
Miche Carbon/ Alu Seat post clamp, £10.
Deda Zero 2 11cm stem, £20.
Deda RHM-02 bars, £20.
Specilized Roubaix bar tape, £15.
Deda Dog Fang, £5.50.
Shimano PD-T780 XT SPD pedals, £44.49.
Swissstop Flash Pro Green brake pads, £19.54.
Token TK-B156 black aluminium bolts £6.28
Token CNC Alloy Valve Caps black, £2.24.
Elite Custom Race Stealth bottle cages, £15.
Total cost £1133.32.
I am open to offers for it. I'd like to make as much as possible back on it but I do expect a slight loss, and someone to get a bargain.
If you are local, I'll happily tune it up for you, if you want, in the future, if it needs it. Or I'll show you how. Should be fine for a long while though as I have pre-stretched all cables, which are all top of the line Shimano stuff.
I'll give the buyer a bunch of spare bits with it, chain, tubes etc.
The frame dimensions are:
Seat Tube C-T 54cm
Virtual top tube 55.6cm
Actual top tube 54.7cm
Head tube 15cm
Chainstay 42cm
Wheel base 99.8cm
BB drop 6.5cm
Seat angle 73.5
Head angle 73
I am located in Preston, Lancashire. I am willing to drive and meet you if you live far away. Or I will consider posting it.
Seat Tube C-T 54cm
Head tube 15cm
Chainstay 42cm
Wheel base 99.8cm
BB drop 6.5cm
Seat angle 73.5
Head angle 73
