BigTam
- North Shields
Complete top-of-the-range brake cable set designed to suit Shimano Dura-Ace 7900 and Ultegra 6700 Road bike brakesets
Die-extruded PTFE coated inner wire leaves a smooth surface for low friction in use, and stainless steel provides smooth shifting and higher corrosion resistance
Includes 1.6 mm PTFE inner wires (1 x 1000 mm and 1 x 2050 mm), and 5 mm outer casing for a complete bike (1 x 800 mm and 1 x 1400 mm), and all end caps
Outer casing is lined with a polymer sheath to assist with the smooth operation of the inner wire, brand new.
£20 posted
£20 posted
