From specialized.,,this is the double, the above was the triple sorry.
FRAME
Specialized FACT 7r carbon, triple monocoque construction, Designs for Women compact design, Zertz inserts
REAR SHOCK
N/A
FORK
Specialized FACT carbon, monocoque construction, full carbon legs, crown and steerer w/ Zertz inserts
HEADSET
Specialized Mindset Plus, 1-1/8" integrated threadless, sealed cartridge bearings, 20mm alloy cone w/ one 10mm and two 5mm alloy spacers
STEM
Specialized Comp-Set, 3D forged alloy, 4-bolt 31.8mm bar clamp, 4- position adjustable
HANDLEBARS
Specialized Womens, 2014 alloy, short-reach drop, ergonomic shaping, 31.8mm
TAPE
Body Geometry Bar Phat, cork ribbon w/ 4mm gel padding
FRONT BRAKE
Ultralight dual pivot brakes, Teflon pivots, forged alloy w/ cartridge pads
REAR BRAKE
BRAKE LEVERS
Shimano 105, 10-speed STI, flight deck compatible
FRONT DERAILLEUR
Shimano 105, 31.8mm clamp, bottom pull
REAR DERAILLEUR
Shimano 105, short cage
SHIFT LEVERS
CASSETTE
Shimano 105, 10-speed, 12-27t
CHAIN
CRANKSET
Shimano Compact
CHAINRINGS
50 x 34t
BOTTOM BRACKET
Shimano FC-4500
PEDALS
Silver cage, black body, w/ toe clip and strap
RIMS
Mavic CXP22 rim, alloy triple-wall, machined sidewalls, 28/32h w/ eyelets
FRONT HUB
Specialized forged alloy, 28h, sealed ball bearings, QR
REAR HUB
Specialized forged alloy, 32h, double sealed ball bearings, cassette, QR
SPOKES
DT Champion, stainless 14g w/ ProLoc brass nipples
FRONT TIRE
Specialized All Condition Pro, 700x23c, aramid bead, 120TPI w/ Flak Jacket
REAR TIRE
INNER TUBES
Specialized standard presta tube
SADDLE
Body Geometry Jett women's saddle, microfiber, gel padding, hollow Cr-Mo rails
SEATPOST
Specialized Pavé II, FACT carbon w/ Zertz insert, aluminum head, 27.2mm
SEAT BINDER
Specialized CNC alloy, 32.6mm
