HorTs
- Portsmouth
I want a hub dynamo and I need it to be charge accessories (as well as powering lights), 12mm Thru Axle, centre lock disc, and 28 spoked.
SON seem to be the most recommended if not the cheapest.
The manufacturer suggests the SON28 would be the best for "when other devices are to be operated or their batteries recharged"
My issue is that the SON28 does not come with 12mm Thru Axle and centre lock, only the SONdelux does. The SONdelux suggests it is "specifically designed for prolonged use at high speeds".
I'm not the fastest rider and often I will be off-road so not going much above 10 mph a lot of the time.
Any thoughts as to if the delux would still be ok for me?
