Hi all
I am changing the cranks on my Longstaff from TA Specialites to Spa Cycles XD-2 touring cranks that have the mark XD2R on them and look to be a copy or unbranded version of these Sugino cranks. The bike is a steel triple chainset 130mm rear dropout audax/tourer with 26" wheels. The outer and middle rings are TA Zephyr and the inner ring is TA Zelito.
I fitted a Shimano UN54 bottom bracket in the 110mm length recommended by Spa but the inner chainring bolts are rubbing on the chainstay. I note Sugino recommend a 113mm bb for a triple and so do Rivendell.
I fitted the new cranks to the original 130mm bottom bracket and the chainline needs to come in by about 8.5mm to achieve a chainline of 47.5mm. I have relied on this Harris Cyclery measurement of the driveside length of bottom brackets, which suggests a bb length between 113mm and 115mm.
The distance between the chainring bolt and the stay during this experiment is about 8mm, which indicates 115mm could be tight.
There is a 4mm spacer stack between the inner and middle chainrings - what is it there for? Could I remove it and fit shorter bolts?
Thoughts? Workarounds?
I don't want to start a collection of nearly new bottom brackets if possible.
Thanks
Thanks
