Speaking of Dremels...
swee'pea99
I'm in the process of tidying up the kitchen, and one of the issues is a few of these:
Judging by the look, it's a bit of the mesh onto which they put the skim, secured by a flat head nail. My Plan A is to use a Dremel or similar to remove the nail head plus surrounding mesh, and turn the whole thing into a postage stamp-sized mini-crater that can then be easily filled, smoothed and Bob's my Uncle'd. Does that sound about right? Many thanks for hints, tips and any etcs that come to mind.
I'd just fill, sand, fill again, sand and then paint.
Spiderweb
Not So Special One
North Yorkshire
No need to do that. The plasterboard nail has popped the plaster skim off.
I would hammer the plaster board nail in a bit further, it should have been like this in the first place to stop the head popping out. I’d then put in another plasterboard nail or a plasterboard screw next to the existing fixing and fill over.
swee'pea99
swee'pea99
You guys!
Thanks a lot - as so often. Excellent hints & tips. I think I'll start by giving it another whack...see if I can drive it in a mm or three. It won't take much...but I can't just fill it as it stands, because the head of the nail is actually above the level of its surrounds. But a thump wi' t'big 'ammer sounds just my kind of DIY! Wish me luck, I'm going in...
PeteXXX
Photo Winner
Hamtun
Is this just an excuse to use cutting disc on your Dremel? 😉
