Kevin Alexander
Bought late 2021 but not to my liking and not being used
Full spec from official website
Comes with mtb pedals and will throw in a pair of sidi mtb shoes for nothing
Out of stock on most sites
ACCESSORIES
SWAT
Integrated SWAT door, internal storage system
COCKPIT
Stem
Future Stem, Comp
Handlebars
Specialized Adventure Gear Hover, 103mm drop x 70mm reach x 12º flare
Tape
Roubaix S-Wrap
Saddle
Body Geometry Power Comp, Cromoly rails
SeatPost
Roval Terra Carbon Seat Post, 20mm Offset
DRIVETRAIN
Rear Derailleur
Shimano GRX RX810, 11-speed
Cassette
Shimano Ultegra, 11-speed, 11-34t
Bottom Bracket
Shimano Threaded BSA BB
Front Derailleur
Shimano GRX RX810, braze-on
Shift Levers
Shimano GRX 810 hydraulic brake levers, mechanical shifting
Crankset
Shimano GRX RX810-2 48-31T
Chain
Chainrings
48/31T
WHEELS & TIRES
Front Tire
Pathfinder Pro, 2Bliss Ready, transparent sidewall, 700x38mm
Front Wheel
DT Swiss G540 rim, 24mm internal width, tubeless ready, 24h, Specialized full sealed bearing thru axle hub, centerlock disc, DT Swiss Champion 14G stainless steel spokes, DT Swiss brass nipples
Rear Wheel
DT Swiss G540 rim, 24mm inner width, tubeless ready, 24h, Specialized full sealed bearing thru axle hub, centerlock disc, alloy freehub body, DT Swiss Champion 14G stainless steel spokes, DT Swiss brass nipples
Rear Tire
Inner Tubes
700x28/38mm, 48mm Presta valve
Suspension
Fork
Future Shock 2.0 w/ Damper, Smooth Boot, FACT carbon, 12x100 mm thru-axle, flat-mount
FRAMESET
Frame
Specialized Diverge FACT 9r carbon, SWAT™ Door integration, Future Shock suspension, threaded BB, internal routing, 12x142mm thru-axle, flat-mount disc
Seat Binder
Alloy, 30.8mm
BRAKES
Front Brake
Shimano GRX 810, hydraulic disc
Rear Brake
In total has been used for 1 gravel ride and the other rides have been road use
Total of 674 Km according to strava
£3000 Ono - located in Edinburgh (collection only )
ACCESSORIES
SWAT
COCKPIT
Stem
Future Stem, Comp
Handlebars
Tape
Roubaix S-Wrap
Saddle
SeatPost
DRIVETRAIN
Rear Derailleur
Cassette
Bottom Bracket
Front Derailleur
Shift Levers
Crankset
Chain
Chainrings
48/31T
WHEELS & TIRES
Front Tire
Front Wheel
Rear Wheel
Rear Tire
Inner Tubes
Suspension
Fork
FRAMESET
Frame
Seat Binder
Alloy, 30.8mm
BRAKES
Front Brake
Rear Brake
