Specialized post adjustment issues
Acdacd
Hello-- just bought a 2015 carbon Ruby (women's version) and I can't figure out to adjust the seat post. Can anyone help me out? I've never had to adjust a post like this.
There is a triangle at the base that the post goes into and then a screw that an allen key turns but has a silver c- ring above it that spins. The bolt will turn in both directions getting tighter the further right or left you go-- when you are in the middle it's loose but doesn't move or adjust anything. Thanks!
S-Express
You probably need to remove the circlip first....
lpretro1
With a set of circlip pliers - if you don't have any don't attempt to remove it or you might damage it or scratch your frame!
