2wd
Canyon Aeroad CF 7.0 Di2
Change of plan, so my new immaculate Specialized Tricross Sport is up for sale
Size is 54cm which I guess is medium
This is the Tiagra version not Sora
Brand new in May this year,full spec is below but I have added/changed the following
Bottle holders not included
Spec from manufacturer
Frame:Specialized A1 Premium aluminium, smooth weld fully manipulated tubing, semi-compact Freeroad design, internal cable routing, rack and fender fittings, integrated headsetFork:Specialized FACT carbon legs, alloy crown and steerer, fender fittingsFront Derailleur:Shimano TiagraRear Derailleur:Shimano Deore LXNumber of Gears:27Shifters:Shimano Tiagra STIChainset:Shimano TiagraChainrings:50 x 39 x 30TBottom Bracket:BB-7420 with crank boltsCassette:Shimano HG-50, 9-speed, 11-32Chain:HG-73Pedals:Black cage, body & toe clips with strapFront Brake:Tektro wide cantiRear Brake:Tektro narrow cantiHandlebars:Specialized CX Comp 6061 alloy, short dropStem:Specialized Elite-Set, 3D forged alloy, 4-position adjustable, 4-bolt 31.8mm clampHeadset:1 1/8" sealed Cr-Mo bearings integrated with headset, 20mm alloy cone spacer with 20mm of spacersGrips:Specialized S-Wrap with 2.5 gel padsRims:Mavic CXP22Front Hub:Forged alloy Hub, sealed bearings, 32 hole, for J bend round spokesRear Hub:Forged aluminium, 32 hole, double sealed ball bearings, cassette, Quick ReleaseSpokes:Stainless 14gFront Tyre:Specialized Borough CX Sport, 700x32c, wire bead, 60TPIRear Tyre:Specialized Borough CX Sport, 700x32c, wire bead, 60TPITubes:Standard presta valveSaddle:Body Geometry Riva Road, with steel railsSeatpost:Specialized Elite, carbon wrapped alloy, two-bolt clamp, 27.2mmSeat Binder:Forged alloy, 31.8mmExtra Features:Chain stay protector, chain catcher, derailleur hanger, clear coat
- Lizard skin bar tape
- Black and green SDG Bel Air Saddle
