Spesh Allez, praxis 6806 bearings
gbb
Peterborough
While I've never had a BB30 so don't know about getting into the BB itself, the bearings used will be 6806, an industry standard bearing...in all probability 6806-2RS...ie, with two rubber seals.
Globalti
Possibly fitted inside a Praxis Works BB shell, which is a pretty nifty design but needs a couple of special tools to remove and replace. Nothing to worry about, go for it.
Globalti
No need; I have invested considerable time in solving BB30 creaks and I like the Praxis Works system but it must be installed with lots of grease on the interfaces.
BB30 cranksets installed straight into the bearings can also creak but this requires the use of bearing fit compound, which I have explained in detail several times on CC.
