Spit link advise please!!
Shropshire
Hello All,
Just bought a new (cheapy) Chain for my commuter With a type of split link I have never come across, It doesn't inspire much confidence and I wondered if anyone had ever used them ? If so what results have you had ?
Assuming you fit it properly it should give you no problems at all.
GazK
Wiltshire
It's known as a "power link" (SRAM trademark IIRC) and as others have said, they work brilliantly. Throw that chain splitter away!
BB, I go along with all the others, and since I'm a natural-born sceptic I too was doubtful at first, but I've come to accept them and see the clear advantage. Are you having doubts because you find the thing difficult to install? There is a definite knack to it, you need to have everything clean for starters, a bit of dirt will stop the link snapping together. Have a bit of slack in the chain and squeeze the two plates together when they're not quite in line, they should be offset so that the two pins are closer together than normal, then when each pin is protruding through the opposite plate, slide the plates lengthwise and the pins should snap into place in the narrowed part of the slot. Once properly assembled this link is perfectly secure, I've never heard of one coming apart in normal riding (hope no-one will contradict me here!).
The problem with using a conventional rivet driver on the modern very narrow 9- and 10-speed chains, is that whilst taking apart a link (to shorten the chain) is easy, reassembling it is not so, and can easily lead to damage. Indeed it's through incorrectly joining a chain with rivet tool, that I've had it break on the ride.
Good luck!
jay clock
Massive member
Hampshire UK
Me too! Lots of clunking the day before a 100 mile sportive ride, then it broke 2 miles in. I gave up!.
The power links are great
BADGER.BRAD
Shropshire
Right this is my up date, The chain for some reason jumps like billio on the Smallest rear Chain wheel ( the chain is made by KMC) I tried the original ( after going through the bin, teabags, rotting veg waste lovely) and it works fine) although it is seriously worn. I decided that may be there is not such a thing as a chain which will fit 6/7/8 speed systems so decided to try and find any markings on the old chain to my amazement it was the same make and was marked as narrow as is the new one ! now I'm totally confused ! Running the chain slowly forwards it seems fine, running forwards even under the slightest load on the road and it jumps like hell unfortunately I cannot see what is happening whilst riding the thing. The only thing I notice is the chain runs very close to the next gear down ( it's 8 speed with only a single chainwheel on the front but it does this with either chain and has never been a problem before. Any ideas anyone.
Ps I know this maybe should be in the tech section, just before anyone says so.
Kestevan
Last of the Summer Winos
Holmfirth.
It sounds like the Cassette is worn.
If you've run the same chain for a long time and allowed it to wear that badly, it also causes the cassette/Chainrings to wear to match the old chain. Then when you fit a nice shiny new chain, it no longer fits, and skips like mad.
If this is the case, it's a new cassette and possibly Chainrings too.
