Panter
Just call me Chris...
- Sittingbourne, Kent
So, as I approach work this morning, I notice there's a very slight buckle in the front wheel. Nothing major, just a slight kink to the right on every revolution.
Well, that's no problem for an experienced cycle commuter like myself so at lunchtime I confidently set about the wheel with a spoke key.
Hmmmm, well that buckles gone, but I seem to have a double-buckle elsewhere now. Only a very, very slight one mind, and it's far better than it was, but it's not quite perfect.......
I know, I'll give the spokes a ping. That way, the loose ones will show up immediately and I can tighten them.
Well, it sounded like a Junior school Glockenspiel lesson. Que much tightening of offending spokes and it all sounds slightly better.
So, I give the rim a gentle spin to check trueness against the brake blocks and it doesn't even make a whole revolution before coming to an abrupt stop as the whole affair is now so buckled that it won't even clear the brake blocks....
The next 30 minutes see's me frantically cranking away on the spoke key (that I'm now wishing I'd never bought) and re-checking before another exploratory spin.
Hmmmmmmmm. Now I'm seriously considering getting a cab home rather than run the risk of riding home on the wildly oscillating deathtrap that I'm confronted with.
A cup of coffee later and I'm making some sort of progress. Unfortunately though, I've lost track of the buckles as the whole wheel seems to gently oscillate round the whole of it's circumphrence and I don't know which side to tighten.
Another 30 minutes later and things are far better. Looking down on the spinning tyre, it seems to be tracking fairly straight. It's only when I look at the constanly changing clearance between the rim and the brake pad that it's obvious things aren't perfect but I'm now slightly more confident of getting home.......
So, to my question.
I understand the principle of trueing a wheel, I've read about it many times and have straightened a couple of glitches before when the wheel was fairly new but the problem now is that I don't have a reference point.
Is there any way of measuring spoke tension with a pinch test or something?
Should they all sound the same when pinged?
Should I have just left well alone and taken the offending wheel to the LBS when convenient?
So, to my question.
