Been riding a specialized mountain bike for about a year just for excercise. Decided I like it enough to invest in a nicer bike. Purchased a Trek 7.5 FX about two weeks ago. Really like the bike. I stay on the largest front sprocket all of the time since it is not that hilly where I ride. Use about four of the rear gears starting with the smallest. In the two lowest gears, I can hear a slight chain rub on the front guide and it gets worse if I stand up to peddle. Of course the bike store says some chain rub noise is normal. I have not taken it back in for them to look at it yet. The store is about an hour away. Some of the problem is that the front sprocket looks to not be true causing the chain to weave back and forth inside the guide. Is this normal for a bike like this or should the sprocket be perfectly straight with no chain movement?
