Sram red on giant bikes...
swiftylee
hi my friend wants to build a tcr advanced build.
can he use sram red including crank on this frame.
i dont understand the bb so cant advise him on this
Hacienda71
Yes as long as he matches the bb to the shell on the frame and the frame is Ok with a mechanical groupset.
MikeW-71
Carlisle
It'll probably be a press-fit, but Giant did supply road bikes with SRAM before 2014, so I imagine a SRAM BB will go in just fine.
Hacienda71
It looks from a google search that it takes a press fit bb. You probably need to check with a shop or Giant direct but I would be very surprised if you couldn't find a compatible bb for a gxp Sram crank. The frames tend to be designed to be compatible with any of the major component manufacturers.
