Lozatron
I recently got a Planet X Carbon Pro with SRAM rival (and I'm far from mechanically competent...) and I've had a few issues with the gears - I'm basically a little nervous that I've done something which is either going to be very dangerous to me or has damaged the bike...
- Sort of "pinking" sound on the front derailler - fixed by adjusting the inner and outer limit.
- The chain kept on hopping between gears on the rear derailer - fixed by adjusting the indexing (twisting the plastic nobble around the cable that goes into the rear deraileur
- When I change to a larger ring on the rear it always hops up 2-3 gears - is this normal or did I do something daft with the indexing?
Thanks in advance for any and all help
