Sram S7 hub gear problem
ren531
Lancaster uk
Does anyone have experience of the Sram S7 hub gear been commuting with this for more than 2 years mostly reliably but I'm having trouble with the gear change ,the indicator rods are good the adjustment is good ,its either the click box or the twist grip ,the cable snapped in the twist grip but I think this is because of the cable backing up inside the grip due to the click box not pulling in the slack cable ,I have a suspicion that something may have got bent in side the click box ,even when the click box is not connected to the axle it will only go from gear 1 to gear 4 most of the time ,the hub itself is an excellent robust thing but the cable and click box are a fussy delicate faff , need a bit of advise if anyone can help .
