Steering damper for ex-Royal Mail bike... help please
Flight
Hi there.
I've got one of those Elephant Bike ex-RM bikes and have just started using it properly after years on a Workcycles FR8 with a child on board. I love it, but because of the centre stand, the front wheel flips about whenever I park it.
I was going to order a Hebie steering damper to keep it still, but don't know if it will fit the RM frame as it's got such a deep crossbar (it's the step-through type). I wondered if anyone has used one of the dampers and would be able to tell me whether it would fit this sort of frame or not.
Many thanks.
alicat
Staffs
Dunno. Could you post a pic of the frame and the damper? What's the financial risk if you order it and it doesn't fit?
F
Flight
Hey Alicat. It's one of these https://www.cycleofgood.com/products/elephant-bikes/elephant-bike/ and the dampers I'm looking at are these Amazon product ASIN B001EIAW4QView: https://www.amazon.co.uk/Hebie-2154800000-Steering-Damper-Crystal-Measures/dp/B001EIAW4Q/ref=sr_1_1?crid=12M05L5RXRWSG&keywords=hebie+steering&qid=1656667435&sprefix=hebie+steering%2Caps%2C66&sr=8-1. Financial risk is low but they sell different sizes and I'd prefer to get the right one, if any of them is likely to fit.
Thanks for the reply.
classic33
Leg End Member
It will not fit the bike you want it to.
Note the clamp that fits onto the downtube, then compare that to the downtube on the mailstar.
alicat
Staffs
The bikester one seems much cheaper to use for a bodge. I'd get the cheapest one I could find and then bodge the fitting with cable ties etc. Or even use some bungee rope if you can be sure it won't turn into a catapult if it comes loose.
F
Flight
Thanks v much Alicat. I might just go for the cheaper one and see what happens! Can always keep it for a different bike if it doesn't fit... come to think of it I have a batavus in the shed that has the same problem. It might fit that one.
Appreciate your help guys.
alicat
Staffs
That sounds like a plan. Fitting it to the Batavus will help you work out what you need/can bodge for the ex-RM bike. One last thought, I wonder what RM use(d)? Or if they even cared....
F
Flight
Yes good question. No sign of anything suggesting they cared! But it would have been hellish with the front basket full of mail especially
alicat
Staffs
I do have a steering damper on a bike similar to a Batavus with a side kickstand. It does help slow the speed of travel of the front wheel but it doesn't eliminate the problem entirely. Just to manage your expectations....
Dogtrousers
Kilometre nibbler
One of the reviews says
Reviewed in the United Kingdom on 5 August 2020​
The kit looks solid and come with a good instruction manual
If your bike has an oversized downtube buy the other model B002NGYHMG instead​
I think that may apply to your bike perhaps?
F
Flight
Thanks Dogtrousers, yes, you're right. I think the one in the second link is perhaps the 'other model' the reviewer refers to... I hope so anyway.
