Stout hub skewer ?
beachcaster
sussex
I need a replacement 8mm oversize quick release skewer for the Specialized Stout Hub on the front wheel of my specialised enduro
can anyone point me at a source as I cant seem to find
on the net.
Thanks
barry
G-MAC
Essex England
on the net.
Thanks
barry
www.chainreactioncycles.com
Not sure if this is what you mean
ultraviolet
it can't rain all the time....
Hythe, Kent, UK
helma said:
I recently acquired an 04 stumpjumper pro disc, and the front skewer is missing it's end nut. This is not a normal skewer. It is a combination axel/skewer. 9mm diameter, i believe 135mm shaft length. The entire skewer is hollow, so technically I could take off the qr lever on one end and put a standard skewer in, but i'd rather get a correct end nut. The official name is a skraxle. I can't seem to find them anywhere though, even ebay.
Does anyone know where I could buy one of these Skraxles, or atleast an end nut for one?
thanks in advance
Cheap SEO
get in contact with Freeborn, they distribute Specialized
http://www.freeborn.co.uk/brands/specialized
hope that helps
baznav
DT Swiss make the skewers the downside is they are £50 a pop, should be able to order one from any shop that deals with madison they distrbute DT.
battered
If you only need a nut will a normal M8 nut fit? I'd recommend a high tensile variant for security, in any case engineering suppliers sell these for loose change.
