Strange calliper brakes?
Paulus
Barnet,
They will bolt in from the back of the fork or rear bridge, but the bolt/screw does not go all the way through. They are normal dual pivot calipers.
Will1985
Norfolk
I bought a set of TRP 925s (TRP is to Tektro as Lexus is to Toyota, and 725 = 925) a few months ago - the rear fits on both front and rear, but the front didn't work at all...5 different forks and none of them had enough clearance, even TT specific ones! The fronts only work on a handful of frames.
I've seen a 726 used as a front on a Cervelo to minimise the frontal cable profile.
