If you are a paid subscriber and make use of the tracking feature so others can watch your live progress it will use a tiny amount to periodically upload your location.So I guess if you don't press stop until you are within range of a wifi connection it doesn't use your data at all?
You don;t need to subscribe tto use the beacon feature that allows a named person to see where you areIf you are a paid subscriber and make use of the tracking feature so others can watch your live progress it will use a tiny amount to periodically upload your location.
Other than that the data use will just be the background chatter used by your phone’s location services using WiFi AP lookups to assist the GPS engine.
No, it only uploads when you press Save. That needs to be within range.
You can stop your ride and discard it if you so choose. You can stop your ride anytime.
Yes but your phone will rely solely on satellite reception to determine its position while you are riding. Minimise signal loss by keeping it in your back pocket where it will have a good view of the sky. Having said that, modern phones use Galileo and Glonass as well as GPS so lack of satellites in view isn’t the problem it used to be.Does that mean I can ride with data/wifi disabled and then when I get home, I can enable data/wifi then the ride will upload once I press save?
