Hi, I've read loads of FAQ's, forum posts and youtube vids but still can't understand where I'm going wrong with my front derailleur setup:
Just had a boxed bike delivered and was playing with the gears (Sora). Front changed from small to big ring fine but then when I tried to shift back down the derailleur didn't move at all. I assumed the cable was too tight so I loosened the cable anchor and the derailleur shifted straight back down to the small ring. Pulled the cable a bit tighter and same happened.
I tried loosening the cable off slightly and then shifting up again but this time there's no 'click' and although the derailleur moves up it doesn't stay in position.
I'm assuming that the high and low screws are ok because when the derailleur is in position the chain is running on the rings fine.
Grateful for any thoughts?
Matt
Matt
