Rear derailleur spot the difference
roubaixtuesday
self serving virtue signaller
Ages ago swapped the inner cable ahead of upcoming tour. Couldn't get it to index properly, so replaced outer too. Convinced myself it was OK but couldn't quite get it properly indexed across the whole range. Seemed to get even worse on final test ride yesterday; started worrying about bent dropout as only remaining possibility.
Happily, problem now (I think!) solved.
Spot the difference before:
And after:
Big John
You've anchored the cable correctly in the 'after' photo and the cable looks nearer to the chain stay than 'before'. You turned the gizmo for holding the cable 90°. Do I win a prize? 🤔
R
roubaixtuesday
A jam sandwich on its way to you! I thought the tab on the plate was to hold the cable in place; it's actually too locate the plate correctly against the RD.
R
roubaixtuesday
That cable fixing plate makes funny things possible: https://hubbub.bike/hubbubs-original-shimergo-solution/
There are several bikes here where that - it works good enough.
E.
Ha. One of my moments of paranoia yesterday was that I'd managed to fit an 8 speed rather than 9 speed block, hence the slightly off indexing. Ironically perhaps it would actually have worked perfectly with an 8 speed block installed as it was!
Dogtrousers
Lefty tighty. Get it righty.
So it's the little plate on the pinch bolt thingy? A reasonable looking, but wrong, positioning nadgers the indexing?
This makes me extra satisfied with my decision to always get the LBS to do my recabling. The ways to bugger up indexing and mis-feed cables are so many and varied.
R
roubaixtuesday
I don’t disagree, but draw the opposite conclusion for my own situation.
When a cable snaps a long way from home or LBS, I now know better how to fix it.
Last tour, we had one snap in the Cévennes; when it next happens I won't make this mistake.
The other lesson is always to take a photo before you start so you don't put it back wrong!
winjim
Not something I've ever been caught out by. No siree, not me, never ever, swear on my life, cross my heart and hope to die stick a needle in my eye.
Dogtrousers
Makes sense for you. But the worst case for me is going to be riding a few miles to a railway station in Kent in a high gear. I can live with the risk. :laugh:
And having had a cable snap inside a brifter once I now replace (or rather, get someone to replace) my gear cables fairly regularly as that was seemingly unfixable (my LBS fixed it for me somehow, using secret magic).
100% agree on the take a photo first. Whenever I do work on my bike I take a ton of photos. It doesn't stop it ending with me going the the LBS saying "I've buggered this up, can you do it properly please".
winjim
Quick check in this specific situation is that the cable should pull in a straight line. The bend in the top photo is a clue something's wrong.
