They are the so called cyclic numbers.
According to Wolfram:
A cyclic number is an
digit integer that, when
multiplied by 1, 2, 3, ...,
, produces the same digits in a different order. Cyclic numbers are generated by the
full reptend primes, i.e., 7, 17, 19, 23, 29, 47, 59, 61, 97, ... (Sloane's
A001913).
That certainly rings a bell from the days when I knew anything about number theory, and doesn't correspond to the sequence given. (Point of pedantry - what spire's been given is a sequence, not a series).
1 is coprime to itself and the coprime of numbers less than or equal to itself.
Are you saying that the sequence is the sequence of numbers which are coprime to their totient? If so, how does spire get 23 as the next in the sequence? For what it's worth, if this is a generic IQ test I suspect the question, or spire's typing of it, is a misprint.
[edit]
I've found the wikipedia definition of cyclic numbers, which does go along my's definition. But the next one is 17 - all primes are by definition cylic (using this definition of cyclic). It's a bizarre IQ test which demands knowledge of both composers' birthdates (Bach
- at least JS Bach -
was born in the 17th century, in 1685) and of group theory.
I think the real answer to spire's question is that it is the list of exercises set for course MA166 at Purdue to be delivered on 28th March:
p733:1,2,3,5,7,11,13,15,23,27
