berylthebrompton
- Bristol
Hello
I am having an issue with my 6 speed Brompton. The hub keeps slipping when in the 3rd hub gear (hardest gear, when the indicator chain is loosest), or 5th and 6th gear overall. I opened the hub initially to re grease the bearings, but afterwards the gear started slipping. Both 2nd and 1st are fine. I adjusted the indicator chain, but the issue carried on. So I opened the hub again and found the actuator plate had broken! So I cleaned up the grease I had added and got a replacement actuator plate (https://www.sjscycles.co.uk/hub-spares/sturmey-archer-actuator-plate-for-driver-hsa470/), but this issue has carried on. I can’t figure out what I have done or how to solve it! Can anyone offer any advice?
Cheers,
James
Cheers,
James
