What would I be letting myself in for if I were to attempt to replace the wheel bearings on one of these?
I've started restoring my Rudge at long last but the back wheel bearings are a little gritty and it doesn't turn as freely as it should. The hub changes gear cleanly and makes the right ticking noises.
I filled it with WD40 to try and clean it before putting in normal oil.
Also it's the old type with the threaded sprocket. How can you hold it to unscrew the sprocket. I was hoping to lower the gearing to something more sensible for a 40lb bike.
