Shut Up Legs
Down Under Member
Greetings, fellow bicycle cammers!
Having recently bought a GoPro Hero3+, I've been investigating the best way to mount my existing Hero3 on the rear of my bike. I plan to use the Hero3+ on my helmet, as it's lighter. My first attempt at mounting the Hero3 was this:
During my 1 hour commute to work this morning***, the rear camera twice slipped slightly on its mount and ended up pointing down at about a 45° angle, so I had to right it, tighten one or more of the mounting bolts, and continue riding. As you can see, I'm just using the mounting parts which can be bought with the GoPro: the handlebar mount, plus one of the mount extenders. I also attached a digital camera lanyard to the GoPro's rear door hinge, and looped the other end around the rear reflector, so if the mount does break, the GoPro won't go far.
I have a few ideas about how to fix this, but any suggestions from you all are welcome! I'm considering the following:
*** Relatively speaking, as it's still completely dark when I arrive at work before 6am .
### I've done over 70,000km on this bke, and it has an impressive collection of scratches and nicks, a perfect example of beausage!
- Stop using the Battery Bacpac, to extend the battery life. My current commute is slightly shorter than it used to be, with elapsed time about 95 minutes, which is just inside the Hero3's battery life when in the 1080p 30fps mode (the best mode for low-light / night conditions, or so I'm told: feel free to correct me on this). Leaving the Bacpac off will make the camera about 50g lighter, reducing the chance of the mounts slipping down under its weight.
- Put a cable-tie around the mount, from just below the camera's waterproof housing to the right seat stay, and tighten it just enough to prevent the camera mount slipping down. I'll put one of those clear frame protector patches around the seat stay just where the cable tie goes around it, to stop my already scratched and nicked frame from getting even more of them###.
- Find an alternative mounting system, which won't change its position due to vibration. Suggestions, anyone? I admit I haven't done my research on this, although I plan to.
