An interesting idea and a couple of points
- Can you change gear when under extreme load. When hill climbing?
- chainrings are effectively square, which makes the leverage variable as it rotates? The "egg" rings are designed to increase the gear at the point where you can apply the most force. These are at 180 degrees. With yours, the higher loads would be at 90 degrees, so on two of the points, the load would increase at the point where your legs have the least power output. Don't know how this would actually feel like when riding or would it be noticeable.
- if you are going to couple this with a 10 or 11 speed cassette at the rear, I don't know if the extreme chain lines would cause the chain to derail?
Good luck with the trials
Keith
Only limited road trials so far, so no data, but it should change gears no matter the load since the gear segments change radial position when not engating the chain. Those sections engaging the chain can be under whatever load, and it won't affect the ability of the non-egaged segment to change position.
Some have seen a similarity to oblong or irregular chainrings, and both as and advantage and a disadvantage. The relative position of the crank arms to the gear segments could be easily redesigned for optimal effect. It does seem, though, that the square-ness of the chain path when VECTr is in expanded position (lumpiness) will not be as noticeable since larger gears are used on downhill or level roads when the pedal momentum is at play, and crank loads are not heavy.
In more contracted settings, the squareness would be less pronounces, and in the smallest position, non-existent.
I suppose a chain guide could allow the use of cassettes, but installing VECTr on the rear hub would maintain a consistent chainline, and eliminate the problem of chain drop (as well as reducing chain wear).
Thanks for you interest and support.
