Tea? (Part 2)
Status
Not open for further replies.
Night Train
Maker of Things
The ballet magazine on the table here has a lead article - headlined.
Can you improve your arch?
My Arch is absolutely perfect so 'No'.:wub:
(And should you fake it?)
Over to you NT. ;)
Only if you are less fortunate then I am and have to make do with this.
:whistle:
Overconfidentii Vulgaris
Here's a bit of engineering output from me today.:dance: Not to NT standards of course but I've come up with these:
As is completely obvious :unsure: they are mudguard extensions which will replace what I currently have on the knockabout bike:
The tape which was temporarily holding the front mudflap on has finally come unstuck with all the spray so I thought a slightly more permanent fix would be a good idea.
I'll fit them later in the week and will put the vinyl mudflap on to the Raleigh.
twentysix by twentyfive
Clinging on tightly
Over the Hill
The tape which was temporarily holding the mudflap on has finally come unstuck with all the spray so I thought a slightly more permanent fix would be a good idea.
Excellent idea. Where do you get the flap material? I used a supermarket meat dish. It's a bit, well, naff :sad:
The new bits are made from some 1mm aluminium sheet that we had in the shed (left over from a repair on a caravan if I remember right) which is light and easy to work.
The old bits are a proper vinyl mudflap off an 80's British Eagle on the front and a section from a lemonade bottle on the rear.
Night Train
Maker of Things
Does anyone else have a vision of NT's house with 25mm holes drilled in EVERYTHING? Like, walls, stairs, tables, curtains...
I am making 'sort of 25.4mm seat post clamps' in 24mm thick aluminium. For the amount of effort I might as well have bought some but they are a bit weedy at that size and not quick release.
Night Train
Maker of Things
Nice bit of panel beating there.
I made some rubber ones for Emily, my winter hack, but the rubber is a bit thin so I might have to use a detergent bottle.
Status
