172traindriver
Good morning folks.. Bright but breezy here at the moment. Supposed to warm up again this week.
Out on the bike, with wind assisted return??
Late running?
Pilot has either filed the wrong flight plan, or they're lost!
Isle of Man is out there, to the left, in the Irish Sea. Birmingham?
How'd you manage half a ride?
Flew overhead, checked and it was the only rotorary wing aircraft nearby.
Off to drop a present off to you Classic?![]()
He missed if that was what was planned.Probably dropping a giant Toblerone on you![]()
Leave the door open overnight, it'll do it whilst you sleep.Not at all Mr Classic, I was busy defrosting the fridge![]()
Switch off at the mains to avoid wasting electric first though.
Very little wind last night, one thing less to work out.Not easy hitting the target from a height![]()
Had stuff in there so didn't want it to defrost, so I stacked the drawers up, and put bowls of hot water into the freezer compartment to help with the thawing. A couple of towels at hand to soak up the water and it was quickly done.
Then breakfast and followed by an 85 mile bimble![]()
Odd thing was it didn't divert around the nearby windfarm as most do.
If it works, why replace it though?I solved that problem by buying a fridge/freezer that doesn't need defrosting. Simples![]()
Some of the blades are bigger than the helicopter!Flew close by to provide extra wind to get the turbines turning??![]()
I have seen them Mrs D, but as the current one works perfectly why throw it away for the sake of it and buy another one? If and when it gives the ghost up that will be the way forward![]()
