Tea?
welsh dragon
Good morning everyone. :rain:
Shaun
Founder
Have a look at this & this post I am constructing now, notice the overlapping options on the line & the "are you sure you want to like this post" B0ll0CKS I get every time I want to like a post.
I see no option to log out which might fix the problem, but I can't log out.
To log out you click on your username (upper right) - but in your screenshot it appears the tap-target is overlapping the navigation links (you can just make out your username, melded into the middle text).
Try turning your phone on a side so it displays in landscape mode - see if that puts your username link in the right place, then tap it and select 'Logout' at the bottom.
If that doesn't work, just click this link and confirm you want to log out: https://www.cyclechat.net/logout/ :okay:
Cheers,
Shaun :biggrin:
SteCenturion
I am your Father
Cheers,
Shaun :biggrin:
Cheers Shaun,
I believe it to be a smartphone issue, it does correct the skewed options bar in portrait as you suggested.
There are several issues created by the update, not limited to CC either, such as having the "are you sure you want to like" every time I like a post & now I discover, not uploading a photo.
My reply options are limited also with no access to smileys or bold/italics etc.
I shall have to get it fixed somehow.
Shaun
Founder
@SteCenturion that sounds like Javascript is disabled - check your browser options to see if you can enable java in the settings, or possibly try an alternative browser application if you have one installed, just to see if it "behaves" in that one?
Cheers,
Shaun :biggrin:
Motobecane
Kentish
Good afternoon people More rain forecast but at least it stayed dry for dog agility class.
Motobecane
Kentish
Earring of the day:
SteCenturion
I am your Father
Cheers,
Shaun :biggrin:
I tried it .....
It worked :wahhey:
Cheers @Shaun , it was driving me mad, took a while to find the option to enable it, but now all is well in the World.
SteCenturion
I am your Father
And the factory reset, no longer required?
Absolutely not, no, thankfully.
I had already deleted a shed load of screenshot's & other chaff ready to transfer the files across to the laptop.
Now I will have to find some of those images again for profile photos, funny quips & the like.
While your on, we have Bradford Bulls & Halifax visiting for the next two Sundays, two of our best fixtures of the year in our League & always have good craic with the West Yorkie fans.
