Bobby Mhor
- Behind You
One for you to work on, Bob.
Started in Buenos Aires early Sunday,
touching down in Barton airfield, west of Manchester, then from there to Dublin. Doesn't quite make it to the airport, coming down just outside.
Took an odd approach to the airport area. Turning NW, and flying low over populated areas.
Flight Code: D000
Shown as a US military flight.
Which shows it as various aircraft, from an private helicopter to a C-130. Tracked this evening after it left Barton, using sqwauk 1177(In contact with London, changing to 3716 once over Ireland) to the "landing" in Ireland. It's not the other aircraft showing on the runway at Dublin in the 2nd picture. That was an Aer Lingus flight.
What are miscodes?
A deliberate attempt to hide the aircrafts identity?
Carrying someone/something important?
They still have to clear the flight at top-level and with ATC no matter, only the plane movements is declared, not the purpose and mission. ATC only need to know the intended flight plan which has more likely given to them from our 'secret' mob...
ANY plane movement has to let ATC know each time they enter a new sector, can't have flights doing what they want with esp so many planes across the country, apart from that I dunno...
There are forums which this might have popped up, but I don't visit any TBH.
There is a seperate MIL ATC but the main ATC still needs to know who's flying, they would just scramble jets up to intercept..Ejitt will probably tweet about it overnight, as his rantings are well known. Up here, he is regarded a Fud....
