Tektro hydraulics same as Shimano ???
I just wondered if tektro draco's are same as any of the shimano's they look similar and I wondered if the bleed kit you can get for shimano's with the screw on reservoir cup thingy would work on the tektro's and would shimano or other easy to get hold of mineral oil work or should it be tektro oil only ?
Any info much appreciated,
Deano
lpretro1
Think it is a different size bleed port fitting for the Draco. Any mineral oil will do. Cheap bleed kits available from Epic Bleed Solutions
ultraviolet
it can't rain all the time....
Hythe, Kent, UK
if you brought the brakes by them selves they come with a bleed kit in the box. Upgrade Bikes distribute them in the uk, just phone or email them and get a part number which you could order them most bikes shops
