What sort witchcraft is this? Why doesn’t it crash into the trees?
It is using AI based GPS and cloud based sensing and uses a zero debt algorithm to ensure a success based outcome process in order to implement a success pathway-forming concept which can be inserting into the guidance system to ensure a collision proof direction analysis that results in a path resolution at an above-ground altitude while using proximity sensors system to ensure an avoidance mechanism for potential collision possibility are eliminated via a direction modifying concept algorithm in parallel to the multi algorithms running alongside the main source-based following priority concepts
See - I should have stayed working in IT
I could have been a manager!!!!
(i.e. I am good at making up complex sounds b****x)
