tightening a brooks saddle
Rohloff_Brompton_Rider
Formerly just_fixed
hi all,
i tried to tighten my brooks saddle last night but the nut just turns and doesn't seem to do anything. which way do you turn it and what is supposed to happen? is the shaft supposed to extend out of the threaded bit or is the the thread meant to come out more?
cheers
Formerly just_fixed
nobody know?
Rhythm Thief
Ross on Wye
Don't touch it, you'll knacker your saddle. I've had a B17 for twenty years and I've never needed to adjust it. I was given a special spanner by the bike shop when I bought the saddle: they said "This spanner comes with the saddle. When you get home, throw it away."
PpPete
Chandler's Ford
You sometimes get the odd one that goes slack .. leather is after all a variable natural material.
Tighten it up if you have to. i.e. more length of the "bolt" forward of the "nut".
ASC1951
Yorkshire
shauncollier said:
i shall leave alone then. just seems a bit slack and i feel like i'm sitting on the back frame.
I have several Brooks saddles, some from new and some very ancient. I'm not particularly light, but I have never had to tighten up any of them. I suppose if you got this one secondhand and someone had already neglected it - e.g. by over-softening it and being a real heavyweight - it may need tightening, but I would go very carefully if I were you. You could always ring Brooks for chapter and verse.
How about putting a couple of pics up here for us to consider?
Mycroft
was considering posting this very question.
My Flyer has about 2000 miles on it, but has got a rattle/bit loose at the nose end, its hard to describe, lightly holding the nose between finger and thumb and wiggling it the bolt seems to shift and rattle, the leather nose I hold also wiggles about a little.
I ordered a spanner as i didn't get one with the saddle, but believe me this thing was NEW because it was a bugger to break in!
anyway a turn of the spanner in the appropriate direction NOTHING, another turn NOTHING.
a few turns later and the nut seems to not be wiggling/lose any more, but the leather is still moving about a bit.
anyone seen this before? know what to do?
its SO comfy, one of the things on my "this is what money is for" list
Greenbank
The nose bolt on my Swallow keeps undoing on its own. After about a week I can put 3 or 4 complete turns on it with bare fingers. I should really put some threadlock on it and sort it out once and for all.
You do need to be very careful not to overtighten it, which is very easy to do, but the whole "don't ever touch the bolt" is a bit over the top (too many people take Sheldon's words on this as gospel, and not wishing to sound callous, but he's not around any more in order to revise them).
Without tightening the bolt on mine I would have had to have binned it. The leather had dipped enough that it was touching the rails. By re-tightening it I've saved it, and it's served me perfectly well for plenty of long distance rides (including 1400km of London-Edinburgh-London) and shows no signs of damage. I think I've been careful enough not to overstretch it. I usually only use the spanner to put in 1/4 to 1/2 a turn on top of what I can do with my fingers.
I'd say that some saddles (remember that no two bits of leather are going to be the same) may need the occasional tweak every so often, but unless it's slackened off on its own, we're talking 1/4 of a turn of the bolt at a time, and give it a minimum of 3 months between each 1/4 turn (i.e. max 1 complete turn a year). Most of the time one or two tweaks will sort it out and you'll never have to touch it again for years.
Tighten it too much and you'll cause the leather to stretch. Once it's started to stretch it'll only get worse, it's much more susceptible to stretching/sagging, which starts the slippery slope of requiring more turns and more frequent turns and before long you'll ruin it (you'll either reach the maximum extension of the bolt or, even more obviously, the leather will begin to thin so much it splits/tears).
Over application of Proofide will also cause premature stretch if you ride on it after softening up the leather too much. The main job of Proofide is to replace the natural oils that get leached out when the saddle gets wet (either from rain or sweat). My Swallow sees a small application of Proofide every 6 months or so when the saddle is starting to look dry enough that it's becoming scuffed up along the edges.
Anyway, I really should get some threadlock...
P.S. Brooks Swallow. Coming up to 3 years old in February. 20,000km in all weathers. Stored indoors but gets the occasional drenching outside when I'm in playing 5-a-side, playing football or riding it. Has done individual rides on it where it's been heaving it down for 20+ hours.
Ian H
Ancient randonneur
The Swallow's thinner leather than, say, a Pro. I tried one but didn't get on with it. I have three Pros, the oldest being around 25yrs old. I've put half a turn or so on two of them.
