Time to get back on a Bike...
Flava
Will try keep it short.
Used to be an avid bike user 10+ years ago but due to some health problems i could no longer ride and so on. This annoyingly aided in getting me to a horrible 25st now i am better im hoping to once again get on a bike.
But i'm not sure what is going to be suitable at my current weight.
I was looking at the Carrera Fury and the GIANT Talon 2 2019 not sure if these would fit the bill
Budget is around £600 with room for more if something is massively better.
Am i expecting to much or is this something that will work.
CXRAndy
Lincs
Can you use a spin bike to aid reduce weight. I don't know of bikes other than steel Hybrids that will take the weight you're currently at
biggs682
Northamptonshire
Morning @Flava and welcome with a £600 budget there should be loads to choose form so get out there and visit some bike shops , my thoughts would be to try and get a lightly used 2nd hand machine to start with whilst you test the water and then once you get and keep the motivation going then go down the new bike route
SkipdiverJohn
Deplorable Brexiteer
London
Secondhand 26" rigid steel MTB. Something that will be strong enough to take the punishment of a massively heavy rider on board every time a bump or pothole is encountered. Run that for at least a year until rider weight comes down to somewhere near normal levels.
Kempstonian
Has the memory of a goldfish
Bedford
I would also go the second hand route. Spend £600 on a bike and break it, you're out £600 - but spend, say, £200 on a second hand one and break it you still have £400. Enough for two more bikes!
Or you could buy a second hand bike and a trainer maybe (and still have money left over)?
SkipdiverJohn
London
I would also go the second hand route. Spend £600 on a bike and break it, you're out £600 - but spend, say, £200 on a second hand one and break it you still have £400. Enough for two more bikes!?
Or spend sub-£50 on a secondhand bike and don't break it. Then you've got £550 left AND a cheap beater.
Kempstonian
Bedford
An excellent suggestion, as long as Flava is ok with the mechanical side of cycling. A sub-£50 bike is bound to be less than pristine and will most likely need tinkering with to keep it roadworthy. This could also be the case with a £200 bike though, I suppose...
F
Flava
Many thanks for all the replies lots of food for thought, i may just go the cheaper second hand route first.
