Toilets
Alex321
South Wales
No expertise but is there a risk that if you put silicon across the front water will still leack, collect and start running round the back.
Has the rubber seal between the cistern and the pan perished or was it fitted with muck left between or just worked lose over time?
Debatably a bigger (or easier) job but maybe check the seal. I say maybe/maybe not as I've always felt that silicon needs to be applied to a completely dry surface and if it's leaking you'll need to completely empty the cistern (to stop water to allow it all to dry, then dry it (hairdryer), etc.
Or maybe I'm wrong (no expertise, just some DIY).
If water is leaking arounjd that gap, then you have a serious problem, and need to take the cistern off and fit a new seal, at a minimum.
The brother is talking complete twaddle.
oxoman
My eldest reckoned that when we get older we have to accept the smell of pixx and biscuits.
Webbo2
Aye and pigs might fly, he's 79 and never peed "like a woman" ever! 🙄🤦‍♂️
No, he'd rather spray the place like an over hyper 3 year old, never clean any of it up and then call it "being a man".
Yes, he really is that stupid/stubborn.
I would tempted to say to him. We are not going to clean it up and we will come back with social services and your GP telling them you can’t look after yourself.
Then ask him if wants to end up in a care home rather than sit down to pee.
A bit reality reinforcement sometimes can change a behaviour.
I'm a qualified plumber and (when i was working) a silicone sealant professional.
You can seal the gap between pan and cistern without affecting its function. If the inlet valve isn't shutting off it'll overflow to the outside of the house via a pipe or on a more modern system, visibly unto the pan. If water is escaping from between pan and cistern you'll need to replace or refit the rubber donut.
You'll need to ensure that the two surfaces are clean and dry. I use blue paper towel to mop it out and then a heat gun. A hair dryer would do the job.
Use the best silicone sealant you can find. I use triple protection, mould resistant stuff.
Don't use the quick dry stuff, its sh!te.
Only apply enough to do the job. Be kind to your future self. If you squeeze a sh!t ton in there you'll just make taking the cistern off more difficult / time consuming.
Use a profiling tool to get a nice profile on the silicone after you've applied it. Use the profile shape that's going to give you a smooth transition between surfaces - to make it easier to clean. You can also mask off either side of the the area to be sealed with tape to help keep the silicone under control.
May i suggest that you invest in a quick release toilet seat? The have a push button which releases the whole assembly off its pins, so you can chuck it in the bath to wash it and making cleaning the pan much easier.
I would just add: real men sit to p!ss. It's actually a thing in Scandinavia and Germany. It's considered extremely socially unacceptable to stand at a regular toilet.
T4tomo
^^ Absolutely this. Stand at a urinal. Sit on pan, anything else is just bad manners.
The only exception is the "one knee kneel" something my late father used to do. Loo seat up, effectively being used as a urinal, but the one foot one knee position got you to "splash free" distance.
